Cartrax
Trouble shooting gas odor - getting gas odor under heavy acceleration (more noticeable when tank above 1/2 full), will also get gas odor from rear as sun heats back of car area and slight odor noticed in garage as car sits overnight. Checked under hood, odor does not appear to be coming from engine compartment including canister area. Can't find any leaks under car. Pulled tank boot, inspected filler area, no evidence of leaks and cap is new feels like it's sealing properly. What else should I look for?
Also, how long should FP hold with only ignition on? Mine jumps up to about 29psi, needle shakes then immediately starts falling, within 10 seconds it's down around 3psi, sits there a while before it drops to 0. (1984 Corvette - High Output Fuel Pump - Vacuum Reference FP Regulator - FP gauge attached to VRFPR) That normal or an indication of a fuel line problem?
Thanks.
Thanks.
