LannyL81
- Joined
- Jul 20, 2002
- Messages
- 653
- Location
- Oro Valley, AZ USA
- Corvette
- 81 White/Cinnabar, 96 CE LT4 sil/blk
Is a replacement gas tank available for the '81? Also need the rubber gasket around the inlet, and the foam stip that goes along the top of the tank, and the strip that goes between the frame and the tank...not sure what this stip is made of....it's thin and not foam...but something else.
When I pulled the sender out of the tank, I had to fold the strainer sock to clear the tank opening.....the sock crumbled in my hand. Guess it was time to replace it huh???
Anyone use the gas tank sealing stuff from Eastwood Company? Does it work? I do not have any leaks, but do not want to ever drop this tank again.
Yes I found the build sheet...but the wind tore it into pieces when the tank was sitting outside....bumed.....got most of the pieces...but not all of them....really bumed....
Thanks,
Lanny
Tucson, AZ
Thanks,
Lanny
Tucson, AZ
