Ken
Gone but not forgotten
In his book, Corvette Fuel Injection & Electronic Engine Management, Charles Probst states that
He continues...
Hasn't that been what we've been trying to tell you all? :LFuels do vary though, from one refinery to the next. If you have trouble, try changing brands. As the folks at GM say: Usually, all a Corvette needs is a good-quality gasoline.
He continues...
Again, as long as you are using a good-quality gasoline, there should not be a need for any type of supplemental fuel additive. The refineries will take care of that for you.Some cautionary words on supplemental fuel additives:
From GM's Research and Development: All major (fuel) brands contain detergent additives to keep injectors clean, and other additives to minimize intake deposits. Some 92-93 octane fuels have more additives than 87 octane. GM does not recommend continued use of supplemental fuel additives. Octane boosters, like toluene, can improve performance only up to engine capability. Overuse--adding more than 20% of the fuel--may cause adverse effects or damage original fuel-system components.
With '85-88 Bosch injectors, do not use cleaning additives in the gas tank. Fuel-system cleaners are not recommended, by GM, because of the kinds of materials used in the fuel tank bladder, fuel O-rings, and fuel line hoses. If cleaning is required, use the GM specified procedure. On the other hand, Multec injectors, in the '89-01 models, do not need cleaning, and doing so could damage them.
Also, Gordon Killibrew, of Late-Model Corvette Solutions, and former Corvette Action Center expert, told me that in '89-91 Corvettes, with Multec injectors, using any kind of supplemental fuel additives can cause a breakdown in the O-ring that separates the coil from the housing. This allows fuel to enter the injector coil, causing drivability problems, such as engine misses and roughness. The '92-01 injectors resist deterioration from these types of fuel additives though.
