AKRAY4PLAY
- Joined
- Oct 14, 2001
- Messages
- 584
- Location
- Wasilla, Alaska, U.S.A.
- Corvette
- '77 L-82, black on black. Full mod 406 small block
Fred,
if you have 4g's to throw at just parts, you can build an impressive motor. i got my heads for $1700 and the rotating assembly was another $1500 or so. you do not have to go as expensive as i did, for 400-450hp and 450-500ft/lbs. be carefull right now, i fell into the "it is only going to cost an extra $??? to do this really cool thing" trap. the prices change on all parts, mike stark will give you a good and solid quote for what you need/want. you should be able to get less trick parts that easily handle what you want, brodix or dart heads vs. afr, etc. your machine shop fees can be cancelled out by going with a new gm 400 splayed main block with wider oil pan rails. this block is set up for making a stroker 434 or even a 454. the block runs about $2200 and has a priority main oiling, i will try and get gm part# for you. i think the new block is also set up for a one piece rear main seal, major plus especially for a manual tranny. let me do some more digging for prices and i will get back with you, Brian
Fred.
