GM 151 CAM
DPC Racing
Maryland
1984 Dark Bronze,58 White
Anybody ever use the old 327 350 cam[gm151] in a crossfire?Looks like it might work.
Thanks DPC
447 LIFT 222 DUR 114
I think this is right thanks
DPC
That is not enough info to make a determination.
Lobe or valve lift (w/ 1.5 rocker ratio)?
Intake/Exhaust opening/closing points @ .050" lift?
Duration, overlap and lobe separation angle can be derived from these specs.
Geek the DUR 222 IS AT 050 and the lift is with 1.5 rockers I will try to get more info LSA I think is 114.
Thanks DPC
