J
jedi
Recently I purchased a full set of Goodyear F1 GS-D3 tires and had a alignment done. Great tires, My Vette just hugs the road. After I had them mounted and drove away one of the valve stems failed but I did not know it and drove the car about 200 miles. The car was pulling to the right so I took it back to the shop to have the alignment checked. They found the problem with the tire and fixed the valve stem, the tire pressure at this time was around 5psi. They took the tire off and checked the inside for damage, redid the alignment and rebalanced all the tires. My Vette drives great and I have recived at least 2.7 more MPG to around 19.7.
At $300 a tire should I be worried about tire failure down the road a few months or a year? These are not run flats so I am worried I caused some damage running around with a flat for so many miles. They also uped my PSI to around 40 with Nitrogen as this supposedly is better for the tires.
Comments?
Jedi
Comments?
Jedi
