Got fender cover in A.C pulley
  • Thread starter Thread starter hotrodd
H
hotrodd
Dumb mistake but the fender cover got in the ac belt at 2500 rpm and broke the ceramic wire connector on the pump.Wonder if you can replace that conector,it run's under the ac clutch. Thank's.
You will have to replace the field coil behind the clutch.
Mike
Thank You Stingray,I happy I can save the pump cause it hold's R-12 real well and get's, well it did,real cold.
