W
WhiteKnight
Got the While I'm at it bug after pedal hits floor and the (IP) Brake light comes on
My spongy break pedal has now gone completely soft and the instrument panel break light comes on when the pedal hits the floor. The other symptoms are very low fluid in the front chamber of the master cylinder and a leak from the left front caliper, but not from the line.
So I started making my list of parts I think I'll need and the “while I'm at it” bug hit. So now I'm planning a major suspension rebuild, which it does need.
Now the on the list are a complete 4 wheel brake re-built kit (SS o-ring calipers, pads, rubber lines, fluid, master cylinder, and a SS parking brake kit). “While am at it” might as well replace the dry rotted bushings on the suspension and why not put a front steering rebuild kit on too.. tie rod ends, ball joints etc.. and a steering coupler.. yeah.. and the ride height is low compared to most of the other vettes in my local club. Someone once said that it looked like my rear spring is needing to be replaced but the front springs look “newer” than most of the other suspension and I don’t think they are stock, so might as well get one of those packages with the front/rear springs, shocks and new sway bars.. So thinking since I'm going to have all that apart I should probably do the front bearings too and get one of those greasing tools for the rear bearings, or should I go for it and rebuild the rear trailing arms too?
Additionally I'm wondering if I should replace the rotors with some power slot ones? 'cause I'll eventually be building the motor or swapping it with a crate, but that's probably not happening this round (my wallet hopes). But I am planning on adding the ignition shielding back on.
Also on the list this round are tools like the power motive brake bleeder, coil spring compressor, shock mount remover, pad install clips, alignment shim kit (front), pickle fork set, dial gauge (to check run out) [where can I buy that from] and the AIM, shop and service manuals.
Haven’t even put a wrench to it yet and I'm already off the deep end..
Where should I start? Should I pull the suspect caliper and see if it's been sleeved before?
