M
MagikDraggin
The fella that wrote the Haynes manual must have been having a bad day when he described where the grease fittings are on the suspension.
"You will find three somewhere around each front wheel". In other words, look for them youself ya dumb cluck!
"And you will find one more near each rear tie rod end". Gee....I wonder just "how near" that might be?
On my '96, I find only two in front, for the upper and lower ball joints. (Oddly, there are no fittings on the outer tie-rod ends). I find no grease fittings on the rear suspension anywhere.
Could someone please be a little more specific and direct this "dumb cluck" as to where I may find three on each front wheel and one on each back wheel, so I can go tell Jiffy Lube to buzz off? Thanks
