P
photovette
I was tired of having the dimmest headlights on the road--when it rained at night it could be just plain dangerous. This is my second C3, so I'm sure you're all nodding your heads in agreement.
Well, no more! I installed the 5-3/4" H4 sealed beam replacement fixtures from JC Whitney (475A0475R 13.99@). I hadn't ordered anything from JC Whitney since high school (1978) and I was surprised at the quality of the fixtures--lead glass, very nice. I also ordered 4 130/90 watt all-weather bulbs (815A2016W 14.99 @) (the all-weather bulbs have a slightly yellow light.)
Of course, the existing C3 wiring system can't handle the increased current, so you have to make up a relay based harness for the headlights, but it wasn't any big deal to do. You also need a 140 amp alternator.
Sounds like alot, but you WILL have the best headlights around--including HID systems.
How I have it set up:
Normal Low Beam Outboard low beam bulbs lit 13 amps
Normal High Beam All 4 high beam bulbs lit 38 amps
FOG All 4 low beam bulbs lit 26 amps
SUPER DEER FINDER All 4 low & high beam bulbs lit 66 amps
