joesroad
I'm having problems with my 88 coupe when I start her up. Always takes a few tries before it will fire, after that it runs fine. It has no codes stored so I realy dont know where to begin looking. Anyone have any ideas?:
try cycling the ignition key on and off about 6-8 times with 5 seconds between the off cycle. the fuel pump runs for about 3 seconds every time you turn on the ignition to prime the system so doing this should prime the system up to full pressure and should start right away if the system has bled down do to a leaking check valve.I'm having problems with my 88 coupe when I start her up. Always takes a few tries before it will fire, after that it runs fine. It has no codes stored so I realy dont know where to begin looking. Anyone have any ideas?:![]()
