nh94vette
New member
Looking for a good hardtop for my 94 conv. Second hand or new from a reliable company.
Smooth Line High Performance Composites. www.smoothline.comLooking for a good hardtop for my 94 conv. Second hand or new from a reliable company.
this is your color too
Ebay Item #250071970198
Look on e-bay and there are usually a few for sale that are used original GM for less than the Smoothlines. 89 to 96 convertible hardtops are all the same and will fit your car. Just wait for the right color or have it painted. Make sure it comes with the brackets and make sure the weather strip is good because it is extremely expensive to replace. If you are patient you will eventually see one close enough to avoid shipping.
In addition to getting the brackets, you should also obtain all of the bolts and washers. These cost about $6 to $10 each. Two very important items are the wrenches. The front wrench is a rachet with an long torex head for fastening the "floating" bolts in the windshield bracket to the hardtop. This costs about $30 new. The wrench for the back two bolts that fasten into the vert's soft top slots on the rear deck lid costs about $50+. This is the most important wrench of the two as it is has closed box end circular rachets on each end. The very thin handle allows for the circular rachets to fit over the bolt head for tightening or removal. The wrench is very thin so that it can be removed from the bolt head easily without scratching the interior of the top at the attachment point. Standard wrenches will not work, and the only substitute is an open end wrench wihich takes much longer to use and may scratch the finish of the interior of the hardtop. So, if the used hard top does not have the equiment above, factor these cots into the price. Also check the headliner and the two wires that lead to the defrost system on the rear window. The wires must be intact, and the quick release connectors in good shape. You can always replace the connectors, but the wire is another thing.
Good luck on your search. I have had 4 convertibles and each had hardtops. My 1994 roadster with hardtop is torch red. Having lived in "cold" country all my life, I insist on having a hardtop. Makes for a great ride, as it tightens the whole car. However, this year the 1994 vette, with hartop attached, sits under its cover along with my 2002 coupe in the garage due to the 4+ feet of snow that has accumulated since mid December. Can't wait till spring!!!!
Good information here but I just want to add that you can save a few dollars on the wrenches by getting non factory replacements. The flat wrench (described above) for the rear deck bolts can be obtained for under $10 at Sears and it is an exact match for the factory wrench ecept for the writing engraved on the wrench. It is 8mm as I recall. The Sears wrench and the original factory wrench are so identical that I get them mixed up. As recall the factory wrench may say STAR on it or something like that. The factory wrench also comes with a small black canvas case to hold it. The roof wrench is a common torx size also available in Sears or elsewhere for a few dollars (I forget the size right now). The torx wrenches are for sale on e bay all the time. The washers on my factory bolts won't come off the bolt. Of course if you want all the factory original tools the prices above are right on. Another rare item for the hardtops is the cloth rear deck cover which is rarely seen with the tops.
I have not seen the particular wrench from Sears that you are describing. I have almost all the wrenches that Sears sells, dating from the 50s, and I found that the Sears wrench handles are too thick to use. I had misplaced my factory wrench and tried various Sears wrenches without success. The factory wrench was very thin. Fortunately I found it before removing the hardtop last spring. I hope that the Sears wrench you described is available. Doesn't hurt to have a back-up. Thanks for the information - I'll check the nearest Sears store the next time I am in town.
You were absolutely correct on the wrench. I went to Sears today and found the exact wrench you described for $5.99. I purchased it as a backup to the one that came with the vette. Plus, if I am lucky, someone can work on the other deck bolt as I work on one, so it comes off in half the time. The only difference was that the metric size and SAE sizes were etched onto the wrench and my vette wrench has painted sizes. Same Pat Pending number. Also, it is 8 mm and 7 mm ends. What I was stressing was that the wrench is thiner than most of these type wrenches and allows the closed end to come off the bolt head when the bolt is removed and extends upward. My hardtop did not come with the rear deck cover. The soft top did, of course
Thanks for the info. Hope this discussion helps others who are looking for hardtops. I put mine on at the end of October, drove it once and now it is in the garage - can't get it out due to the depth of snow. at least 2 feet.
