D95
I have a 95 LT1 stock. I replaced all of the seals and opti,waterpump pan gasket and hub seal.The hub is still leaking. I had a stainless steel sleeve put on with GM seals and the hub is still leaking.I put dye in the motor and it is definitely the hub seal.GM does not have the part and I think it is discontinued(hub).I believe the p/n is 12553250.Did this happen to anyone else on the forum?
Does anyone know of a good aftermarket hub?I guess my old hub has a groove in it .
Thanks for your help
