Harmonic balancer is wobbling.
wishuwerehere82
Rochester, NY
Red '82 Coupe,Sebring Silver '98 Coupe
I was putting my 82 L83 away for the winter today, when I noticed my harmonic balancer is out of center and looks like the rubber is extruding out the back.
What are my options?
Do I need to replace anything other than the balancer itself?
Thanks in advance.
You should be OK just replacing the balancer, unless it's loose on the crank snout and has damaged the seal. When you install the new one, put some grease on the seal lip so it doesn't "start dry", and use the proper balancer install tool (not the balancer bolt), and use some sealer in the key groove to eliminate that as a possible leak path.
Reminds me of that song "Flirting With Disaster".
While you're in there I recommend you replaced the harmonic balance seal also. Follow John Z's instructions and you shouldn't have any problems. Note: you will have enough room to replace the harmonic balance seal. It's going to be tight but it can be done. I use a seal puller with a shortened handle or you can use a bent #2 screwdriver and then use the leverage of the screwdriver to pop it out. Also add some sealer on the outer diameter of the new seal and make sure the timing chain cover is clean before installing the new seal. There are some part stores where you can rent or even borrow for free seal pullers and seal installers.
