chevyaddict
Before I go doing the awful task of trying to replace the headlight switch, I was wondering if there might be something else I'm overlooking. My low beams aren't working on my 68. The reason I'm not sure its the switch is because it is somewhat an intermittent problem; kind of like a loose connection. However, all four high beams work and I don't think low and high beams have separate grounds. I already replaced the dimmer switch and all four headlights. Anything else I'm potentially missing or is this a bad headlight switch?
