head lights
  • Thread starter Thread starter kraz
K
kraz
hi everyone can anyone tell or show me how to change my head lights on my 93 thanks kraz
What part do you want to change?
hi i just need to change the light or lamp the hi beam is out on left side thanks kraz
You need to flip the light up then put on park so light stays up.
Remove the headlight cover , disconnect the wiring plug ( under the rubber boot )
If you have removable bulbs they just un clip out of the back.
If you have sealed beams then you need to remove the 4 screws at front that hold the sealed unit into the light mount
You need to flip the light up then put on park so light stays up. Remove the headlight cover
There's an additional trick to getting the screws out of the sides of the headlight covers. After you've raised the lights, like vetteoz says, push the headlight switch in for just a moment, then pull the switch out to the parking light position. The lights should rotate just a little bit so you can get at the screws easily. (Or does the '93 have a twist knob?)
:w
93 will have a twist, anything newer then 89 should have a twist
