soxx35
I want to install headers to my 79 l82 what adjustments should i make to my carb to make up for the better breathing engine. The carb is a stock quadrajet.
thanks rj
thanks rj
Hey.... finally a RI man!!! I live in Narragansett! To answer your question the carb should not need any adj. Headers are a way to remove the pressure from inside the engine more quickly (in most cases). Just a little advice, you may not want to change the stock manifolds. I did and lost some good torque out of it.soxx35 said:I want to install headers to my 79 l82 what adjustments should i make to my carb to make up for the better breathing engine. The carb is a stock quadrajet.
thanks rj
i disagree. I have no problems getting to my plugs or with burnt wires. While they do sit slightly lower then the manifolds, i rarly scrape any worse tehn i did before. The headers gave my car a nice performance boost. I'd recommend em all day long. I've got the ever popular dynomax ceramic coatedRodsnRides said:soxx35, I recommend you keep the stock manifolds and go with a true dual system woth some Flowmaster 40's or similar. I believe you'll find a thread in here about using a 1974 crossmember for the dual pipes. Headers, unless you really plan on flogging it, are a pain. Hard to get at the plugs, burned wires, sit too low (real speed bump detectors) and just generally a hassle. But, they are a performance gain-if you combine as a package (cam, intake, etc.). Have not tried "block huggers"-they may be an alternative.
John Z-I thought the '70-'72 LT-1 cars had bigger exhaust openings than the 2" on the "regular" SBC's. No?
Best regards,
Rick
81 Corvette said:I have no problems getting to my plugs or with burnt
