You won't need a full tune, but you will likely require some PCM tweaks... especially if you switch to no or hi-flow cats at the same time. There's no danger involved if you can't get to it right away, as these engines typically are tuned rich from the factory (for safety). However, be prepared for intermittent powertrain codes and CEL until you get to it.
Header recommendations? LG Pros, Kooks, and American Racing have proven themselves to be reliable, rugged, and get the job done. I have thermal coated LG's myself. The thing I like about the LG Pros is that they use a slip fit and clamp connection to the exhaust system - no worry about catching or scraping a collector flange on a speed bump or rr track.
As for tuners in your area...
Dez Racing in Raynham, MA is excellent (I used to live in MA).
HTH!
