Ray0214
On my 1995 corvette, both headlights continue running after turning off. I took the passenger side out and replaced the plastic gear and ppellets, reinstalled and it worked perfectly. However when I tackled the drivers side I ran into all kind of problems. First of all the small pin that has to be driven out simply would not budge, not even a little, so, I tried to drill it out thinking I could find a replacement, that didnt work either, it would not budge, and unless I can remove the pin, I cant get the shaft with the gear out of the motor. Getting the pin out is not possible at this point it appears. Also, the bolts on the side of the motor were so tight I couldnt budge them so I quit, afraid I would strip out the heads....so, I am looking at just buying a rebuilt motor and replacing the whole unit. I have searched for a video detailing how to seperate the motor from the bracket and headlight but couldnt find anything. Would appreciate any suggestions anyone might have. Thanks
