V
vintage
Just upgraded from a C4 to a 2000 C5. The "check engine" light came on yesterday. I read the manual, filled up with gas, checked to make sure the gas cap was tight, but the light stayed on. Heard that disconnecting the battery might help. I disconnected negative terminal, then positive. Let it sit for an hour then reinstalled battery, positive first, then negative. Check engine light is still on.... but now might left headlight door comes back open when you shut off the lights! When you turn lights to "on" they both open and shine properly. When you shut them "off" they both close but the left door then comes back open..... HELP! I know... I'm keeping my day job.... but I didn't think I would break it by disconnecting the battery!
