R
rrhayden
Thanks to everyone who advised me on the repair of my headliget motor. I purchased the 3 small plastic bushings to do the repair and found out that was not the proble. As it turns out, there is a steel shaft pressed into an aluminum hub that carries the plastic bushings. The shaft is splined and had come loose from the hub. I scored the hole in the hub with some heavy sand paper and JB welded the shaft into the hub. It looks like it is fixed !!!
Thanks again.
Thanks again.
