Headlight motors
kev
Canada
1966 Corvette coupe
I'm in the process of rebuilding my headlight motors on my 66, my question is what type of grease should I use ?
Thank you
Kev
Don't know if I was correct but I just used regular grease.. Not saying that is correct but just what I used.. No problems yet... Dave..
I used white waterproof grease. I didn't want to use something that would get thick when it got cold.
Ol Blue
Not sure if you saw this post
Thank you
Kev
Kev,
Not sure if you saw the post I submitted here at CAC on 4-1-04 1:29 called 63-67 Headlight motor rebuild. But a great site for rebuilding is: http://65corvette.nonethewiser.net/technical/Headlight_Motor_Rebuild.pdf
However, they don't say which type of grease to use. So, I can't answer your question, but I just wanted to pass this info to you, hope you can use it....
Craig
Thanks alot guys !
1964*Coupe...That is the same info I was using to do the rebuild.
Thank you
Kev
