Lib
Replacing 74 headlight switch. Manual says to lower steering column to remove instr. cluster, and refers back to steering section. Steering section only discusses steering column removal - not "lowering". Is this as simple as dropping the bracket at dash and the bracket at firewall, and slightly lowering the column and wheel towards the seat????
