Vettehead Mikey
PawBobby said:I didn't know that if the headlights stayed down meant you had vacuum.![]()
It doesn't. The headlights will stay in either position quite well without vacuum - otherwise they would rise by themselves sometime after the engine is shut off. The sytem is designed to 'freeze' the lights in their last position should there be a loss of vacuum. Many papers I've seen in print erroneously state that the system is designed to raise the headlights in the case of failure, this is not true.
You only need vacuum to move the lights from one position to another. This means that you need a tight, virtually leak free system and all components functioning correctly. This applies to both the extending and retracting side of the system.
The actuator and locking system is not all that different from an aircraft landing gear mechanism, excepting that most modern aircraft use hydraulics rather than pneumatics. It wouldn't surpise me to learn that GM used this as inspiration for their design.
....because when this happens again, AND IT WILL!!! he will then be able to accept this as .............NORMAL!!!!!!!!!!
