Dunzvett81
I have a strange issue when I turn on/off the headlights. I recently replaced cam, lifters, balancer, chain, both headlight actuators, plastic filter and metal valve. The headlights work great, go up quick both at the same time and go down no problems. when engine is off they will also go down. ISSUE: When I turn on/off the headlights at idle (800-850) I get this slight shake (vibration) in the engine (not missing) which is also felt in the car. It only lasts for about 5 seconds and everything is normal again. This does not occur under normal driving conditions. I have searched the site with negative results. Not a huge deal as everything works great but something must be off. Thanks
