eoseitz
Hey everyone. I've tried to do some research on this and I just wanted to get everyone's opinion. When I first start my car the temp is fine. In fact I can leave it run and it doesn't overheat. While driving on the highway, the temp stays between 160 and the second line on the gauge. After driving it on the highway for a while and coming into town, the temp rises and the car starts to run rough. From what I've read this is due to the gas boiling in the fuel line by the manifold. I replaced the water pump when I bought the car...maybe 3-4 years ago. I can feel water going through the lines when the thermostat opens. The original radiator was replaced by a larger aluminum radiator.
My fan cowl is installed, but the lower spoiler is broken under the car. Would this matter at stop lights?
I was told to check the fan cluth. My fan always appears to be spinning. Should it? What is the clutch for?
I've been told I may have a bad air/fuel mixture or timing. The car seems to run fine on the highway and idles fine when first started. Should I check this?
My father said he thought the corvettes used to have a heat shield over the manifolds. This doesn't solve the overheating problem, but may help keep the fuel from evaporating. Is this correct?
The temp raised almost to half gauge today. I wasn't driving in town long. It may have went higher.
