Heater/AC control light,
lobes290
White LK MI
1979 white l-82
HI, I cant locate my light for the heater/ac controls.
The light for the controls is in the DASH above the gauges. If you run your hand along the dash pad you'll feel it ;)
It is a special bulb with a magnifier tip on it to focus the light onto the console for the heater/aircondition controls. When you remove the center gauge cluster be very careful when removing the bezel.. Every one I've seen has a sharpe edges and will cut or tear the vinyl. Use a small screw driver to help lower the cluster to clear the sharpe edges. -Rare 81
I can not feel the light above the dash pad, is there any difference between the 79 and 81? Or am i doin something wrong? (I just want to make sure before I remove the gauage bezel) THANKS
I've got some of those bulbs at work. If you want the GM part # let me know and I'll post it here in the AM.
I found the bulb, Buglar could you please post the part#
THANKS
