W
wade
hi guys, in the process of removing my evaporator , and the haynes manual as well as the gm shop manual make reference to removing the heater control valve when taking the heater core hoses of the heater core. i have seen the pics in the haynes manual and i dont have this control valve. was this mabe not installed on the electronic controlled units? as far as the shop manual diagrams go, the hot cold selection is entirely dependant upon the opening and closing of
the temp control valve, which is in the housing itself. so why is there a seperate
valve installed just prior to the heater core? and do i need this valve? only funtion of this that i can see is to turn off the flow of coolant to the core.
