Argulace
The heater in my car blows luke warm, not even warm enough to be considered definately warm, no matter how high the temperature is set on the control; including 90 degrees (max).
AC works fine, vent works fine, defrost is same temp as the heater (again regardless of the setting on the dash). The air changes to the floor vents properly when I change the setting to the heater, it also changes to the glass vents when I change to defrost, so I know at least the directional parts are working.
Any advise? Thanks!
Any advise? Thanks!
