steve53
New member
i have a 94 vette and the heater wont get hot. any help will be apprecitated. thanks
thanks for the info, i have checked the flow from the heater core and it is clear, but seems to be not much water in the hoses. i need a service manual for a 94 vette, any sugestions. thanks steve53What is engine coolant temp?
Start by confirming you have hot coolant into and out of the heater core.Core might be blocked and need flushing out
If you do have flow then problem most likely with the things that control the actual temp .
Air blend door / motor is the most common
