K
keith72
OK, I should be able to answer this but I'm going on the "only stupid question is the one not asked" theory. Can I simply drop in a later model HEI distributor to replace the original points?coil type distributor? The car will be a daily driver and I like the relatively low maintenance of the HEI system.
My 72 has a 1972 350 that was originally installed in a pickup according to the serial number. Obviously, it has coil/points etc but the distributor doesn't have a tach drive gear. I will be replacing the tach anyway with the white Auto Meter gages.
Lift me from the abyss of ignorance please.
