S
Sunday's Gold
Does anyone know if the C6 has the heights adjustment bolts that the C5 has?
Any time you change the Ride Hight it will change Caster,Camber and Toe Somewhat!!Sunday's Gold said:thank for your quick reply. How much adjustment is there? Do the wheels have to be re-align?
junk!!About an inch. If you want to go lower you need to modify the rubber stops.Sunday's Gold said:thank for your quick reply. How much adjustment is there? Do the wheels have to be re-align?
Hey Nick thanks for the advise. How much did it cost for the alignment?Nick Smith said:my c6 has been lowered an inch up front and inch and a half in back basically set the car at 3/4" rake to make it look mean and then realigned. I thought it handeled good before but now its pretty incredible next is the big sways we will talk more about handling then and if its not enough then either c5r springs or coil overs but lowering and alignment of the c6 definatley gives better handling and looks as well
