toobroketoretire
Banned
Several years ago I went to Los Angeles and on the way back my 454" engine started missing (???). As I was dead tired and night was rapidly approaching I continued on my way and made it home about 2 hours after dark. The next morning I used my IR gun to see which cylinders weren't firing and found the front 4 were dead. I pulled the plugs (AC Delco R45XLS) and found they were gapped to .055"...............010" more than I had gapped them about 15,000 miles before. I discovered the AC Delco plugs erode VERY quickly and found an HEI just isn't powerful enough to fire .055" plug gaps. The Standard Motor Products ignition catalog recommends the usual .035" plug gaps even on the more powerful HEI's and I suspect it's because they know the HEI's just aren't capable of firing across big gaps. Okay for .045" gaps IF those gaps are maintained but mine had exceeded that amount.
Since then I have switched to expensive Denso #5305 plugs with their .015" fine-wire iridium center electrodes and gap them to .035" to ensure they fire. The wider plug gaps were intended to light off very lean mixtures but as I'm running a #3310 Holley I just don't need huge plug gaps.
Oh yeah, and since I made the switch to the expensive Denso iridium plugs I have found their gaps have only increased about .002" in 30,000 miles so I will continue buying them. Their long lifespan alone makes their additional cost worth it. If I recall correctly I bought them for something like $5.50 each so I got a terrific deal as they usually cost $10 or more.
