Help ASAP ! Acrylic top - HARD Top ???
Idaho Slim
Archer, Idaho
1996 LT1- Blk/Blk. 1996 LT4 - White/Blk
So, 10 days ago, my 3rd !!! replament top in about 6 years broke/cracked ! :mad
3rd "Melrose' replacement top just snapped driving down the road in cold weather, junk tops ---> Melrose imho:mad.
So the issue is; I want to do this replacement with a "hardtop" & paint it to match our car color.
Is there such a thing for base LT-1 coupe "PAINTED HARD TOP" OR were they only made with the 'GLASS TOP" ???
I need to get this fixed asap as winter is fast approaching here, Insurance will make this a glass comprehensive claim, so I am good that way. but I AM TIRING OF THIS CRAP PRODUCT from Melrose acrylic tops.
help !!!!!!!!!!!!!!!
Paul T
Charlotte
1967(427/400),2011(Z06)
C4s came with either or both tops. No problem replacing yours with a painted top.
navy2kcoupe
West Central FL and SE Mass.
2000 Navy Blue Coupe A4 Z51
You might even be able to find a used one already painted to match your car color. :thumb:)
Andy :w
Hot Rod Roy
Mission Viejo CA
Yellow '84 Coupe
So, 10 days ago, my 3rd !!! replacement top in about 6 years broke/cracked!
That's incredible! Is there any possibility your installation procedure might be improved? Would you be offended if I asked you to describe your procedure? Does the frame for your top fit easily into the mounting holes? Does the front edge of the acrylic top have excessive pressure against the weatherstrip, or do the front bolts tighten easily?
:w
Wayback
S-NJ
93 Ruby Aniv roadster/6spd
The painted top on my 85 when off caused a lot of frame flex, The 90 acrylic top was cracked on the Passenger side when I bought it. My 93 has the X brace which really helps the flex issue. Originally the C4's were supposed to incorporate the C'3 T'top but was nixed for some reason. Personally I would have liked that & As mentioned just throw a painted top on.
Idaho Slim
Archer, Idaho
:w
Understand, but all installed by Chevrolet dealership:mad
gmhowe
glendale, az
1985 4+3 black cpe & 96 LT1 CE
I got a new acrylic top from CorvetteTops for $330. does not include the frame but they give a video of how to remove, clean up from the old top and replace it.
Gordon
