racingundertaker
Active member
I have been driving my 73' Vette for a couple of weeks now after taking it out of storage. It ran fine for a few weeks, and then seemed to idle very rough when I had it in gear. I have a 350/auto w/Lunati .477 lift cam. The car does have a "lopey" idle, but it got progessively worse at times but then would smooth out again. The Q-Jet was rebuilt last summer; spark plugs look great. New wires, cap, etc. The car pulls and runs fine under a load. Now this evening I went to take it for a ride, and it wouldn't even idle out of the garage. It started hard; seemed like it flooded; once I held it to the floor, the engine cleared out in a big blue/black puff of smoke. It would idle for a few secs and then just sputter out. The exhaust after it does this smells like a car after it "diesels" when shut off. Does anyone have any ideas what this might be? Is it carb related? Coil related? Timing related? Any help or ideas that anyone can give me would be greatly appreciated! Thanks for all your help!
and much concern on my part. Upon pulling the left side valve cover, it was discovered the valve spring on the #1 exhaust valve was cracked/broken
. The good news is that nothing was damaged internally; a new valve spring is on the way; and hopefully I will have my "hotrod" back on the road this afternoon. I had the same problem last year at almost the same time with the #4 cylinder intake spring. I can't figure out why this happened again, probably just coincidence? It is a hydraulic set up and I do turn the engine over from time to time during storage. Oh well.......hopefully it will hold together for the rest of the summer, and then I will have an even better excuse to remove this powerplant this fall and convert it into a 383 stroker. Thanks for all the suggestions and help! This forum is great!
