W
white02
I have a 2002 Coupe. Every now and then, not every time, when I start in the morning I get "Charge System Fault" in the DIC for about 3 seconds. I have went into diagnostic mode and all I get is "No Codes" so this fault has not thrown off any codes. I assume it has something to do with the alternator but I thought that would generate a code. If C5 Specialist is out there, any thoughts would be most appreciated. Thanks.
