S
silverbullet
My stock 1981 (except for a hypertech chip) has been running great until yesaterday. I'm driving down the highway and come to a stop sign. The check engine light goes on. I smell smoke. I pull over and number 3 spark plug wire is on fire at the spark plug. The spark plug wires are Taylor 8mm spiral wound. They have about 100 miles on them. I get the car home and check the diagnostics and code 51 comes up. (a side note, I never get code 12 first, it just goes immediately to 51). I then replaced the spark plu wires and put the origanl stock prom back in and still get a code 51. I tried in numerous times each time disconnecting the battery in hopes of resetting the computer. I spoke with the local Chevy dealer and they said it sounds like a bad ECM. So I bought a rebuilt ECM from AC DELCO. I put it in the car and tried both chips with and still get a code 51. After my third try with the new ecm the car stopped running all together. I have put all new rotor, cap, wires, ignition module and still nothing. It won't even start with the computer disabled. The battery is fully charged and the starter tries to do something but nothing is firing. Does anyone have any ideas???
