Help for a squeaking front end
  • Thread starter Thread starter ez1
E
ez1
Hi,
Anybody know what's making the front end on my 69 sound like a donkey? It's most noticible when I go over a speed bump. It goes HEEE on the way up and HAWWW on the way down. If I press and rock the front from either side It just screeches away. I had the ball joints greased and silicone sprayed the sway bar ends. Still screechin' Any ideas?
First ... welcome aboard CACC!
Just guessing ... lube the sway bar MOUNTS too. Maybe it has aftermarket polyurethane control arm bushings and they need lube? Or, maybe it has OE-type rubber CA bushings and they're wore slap out? I'd also take a look at the front shocks' shafts ... the chromed ones ... look for rust/schmutz.
JACK:gap
