Arrrrgghh. I've pulled the SR plenum off AGAIN because I appear to have a fuel leak at the #4 injector. When the pump pressurizes the fuel line, I get a small puddle of fuel right below the injector on the manifold. I cannot, however, tell if it's coming down from the rail (ie, the C-lock came loose) or up from the port (ie, bad gasket, which is brand new...).
Any suggestions or simple ways to look? To take out the fuel rail is a major hassle with the SR runners, so I'm trying to avoid having to do that.
[RICHR]
[RICHR]
