I would really like to help on this one. I've got 13 years experience troubleshooting wiring problems on F-16s and F-117s in the Air Force. Unfortunately, I'm in Korea right now and don't have access to my schematics. Based on what I've read so far, you definitely have a short. And, I think it's a constant short. But, only when that circuit is activated, does it cause the problem, making it look like an intermittent short. From what lone73 says, the reverse lights and turn signals use the same fuse, which gets power from the ignition switch. Your short is most likely somewhere between the fuse and the reverse lights or turn signal lights. If a wire is shorted, you may need to bring it to a professional. Since I don't have a schematic here, I can't offer much help in narrowing that down. There are a couple easy things to try though. First, check ALL your light bulbs and their sockets. If the socket gets corroded, it may be shorting through the bulb's metal base. Also, check the reverse/neutral switch, especially the wiring and connector on it. Check for any bare wire, and again corrosion in the connector. I'm frustrated here, because this would be an easy fix for me, if I wasn't half way around the world. I'm curious, check to see if your reverse lights stay on all the time, while driving, or do they come on when you hit the brakes? I wish you luck with this one.
