dmd
Just replaced all my brake pads with original ACDelco replacements and had all four rotors machined on my '96 LT4. My right front is making a constant chirping noise, at a rate that increases with speed. It stops as long as my foot is on the brake pedal, and quiets down if I get the pads good and hot from repeated hard stops. I shimmed it and lubed the shims, as well as the pad clips. I've taken these things apart multiple times and I can't find the source of the noise. The caliper pin is on the bottom of the frame, and the pads were labeled for L & R so I'm confident I got the installation right. The rotors are well above minimum spec and I brushed off the excess rust. If anyone's got any ideas or been through this before, do let me know, it's driving me nuts.
