WhalePirot
I had to do an emergency change in a parking lot. I was amazed how simple it was. The hardest part was getting the rubber overflow boot of from around the filler neck. It is a very simple thing and despite the scary warnings and a bit of disinformation, you should be able to handle it just fine. You don't even get dirty doing it.dburgjohn said:I understand the mechanical part, but the idea of working on wires that will be soaking in gas makes me a little nervous.
I look forward to your post, beaming with pride after you do it.
