curt
adI'm in a tire pressure monitoring nightmare. I have 2004 conv. I put on new tires this spring. First tire change, car has 22,000 mi. A few days later I got the tpm service message. All pressures reading xxxx. I tried to relearn but only left front would learn sometimes. I took it to a shop that specializes in only Corvettes and they replaced the receiving module. It was ok for awhile in short runs. When I drove for about an hour the message came back and the right front read xxxx. I could only learn left front. I dropped left front to 15 psi and drove around about 7 miles. No change in pressure about 32 psi. I went back to the repair shop and they said I had a bad sensor. I didn't think so because the GM hand held said they were transmitting. I replaced all four anyway because they were near the end of their lifespan. All was ok for short trips. On a long trip, about an hour, the message came back and left front is xxxx. The repair shop is now giving me the run around. Is there anyone who understands this system that can help. There is more things I've done but too much for one blog. Any help would be great , I'm desperate. Between this and the column lock problem has me cursing this car but I want to love it again.
