Help with breaks
You might want to think about checking ALL your fluid levels on a somewhat more frequent schedule than whatever you are doing now.
:thumb
It could be, I am guessing, the fluid has never been checked & someone wore the pads down to nothing and (of course) the fluid level dropped.
There is barely any info to go on by the OP.
:eyerole
Check my brakes one reservoir was empty does that mean I have to bleed my master cylinder[/QUOTE. The car has been sitting for five years. I did not see any physical signs of wear it has been leaking. Did a gravity bleed seem like it was working when the car was off break Got hard as soon as I started the motor they got soft. Check my master cylinder did not see any air bubbles when I press the brakes. Did see some fluid come in but I believe that is normal. And when I press the brakes real hard I hear something and the carburetor. ??????
You have a brake fluid leak somewhere in the system. Could be the master cylinder; could be any of the calipers.
:thumb
Where are you located in the US. If you're close to me (Monmouth Maine), I invite you to put it on my lift at no charge so we can both have a look. This is a safety issue.
Chuck M
