James Guard
Can't figure out the high idle issue I'm having with my 85. It wants to idle around 1400. I tried setting the idle with the IAC procedure per the FSM which seems to fix the problem after I shut the car off and restart it, it reverts back to the high idle. I have also adjusted the TPS with no change. Could this be a bad ECM? What else can I check? Also, is there a module that controls the check engine light? I have replaced the bulbs, replaced the info panel, and I still do not have a check engine light to check for codes using the paper clip method. Any suggestions? I'm looking for serious help with these issues. I have put a lot of hours restoring this car to have it not run is not acceptable. I am a Corvette noob so I need the guidance from the experts. Thanks guys.
