S
sscam69
Ok guys heres the deal
I have got my car back on the road but there is a dilema. I let the car idle at startup and I decided to rev it a little. I started to hear an abnormal popping. I decided to rev it and hold it at those revolutions. I kept it at 2500 and I started hearing a lot of abnormal popping. It sounded like someone set off a firecracker in the exhaust. Like a pop in a hollow tube. At first I thought since I had the car sitting for a while the octane might of have gone down, i use medium grade, and it was preigniting (detonation). I have never heard detonation or pinging before so I assumed thats what it was. In either case it didn't sound right. I added octane booster and was not as bad but still there. I took her for a spin and just wasn't to her full potential.
I decided to check the timing BUT the mechanic didn't line up the mark with the position of the piston. Therefore I have no reference point to indicate how many degrees BTDC the ignition is setting off. I think he just set it by ear.
What I did was have my brother rev and hold the rpm's at 2500 and you could clearly hear the pinging. I loosened the bolt that pins down the distributor and I retarded the timing until the sound ceased and sounded "normal". I told my brother to let off the gas and she idled fine.
Was what I did correct?
How can I figure what the actual timing is without tearing apart the engine?
Should I have done it at 3k rpm? Thats when the advance reaches its max right?
Thanks in advance
Frank
Thanks in advance
Frank
