smf402
New member
i have a 2002 supercharged 402 and had a leak in my fuel line, and the car ran like it was on 4 cylinders. replaced the fuel line and it ran great for five min, then ran like the fuel line was leaking again. ive ran a test, and no codes come up. checked my plugs, everyplug on the right side were foulded, and on the left like new, yet all injecters have the same voltage when ive tested them. im lost any help would be great
I think you'll find many good technicians here to help with your problem. Unfortunately, I'm not one of those.
I think you might want to give a bit more information like; Are there any codes set in the computer? Have you checked the fuel rail for blockage on that one side? Is that the same side the leak was on? (Assuming so)
