Hepl installing a Hurst Shifter 80 Vet.
  • Thread starter Thread starter joefloyd
J
joefloyd
I am ready to install a Hurst Shifter in my 80 vet. Can some one tell me if I have to remove the cross member to install it, and if I do what is involved to remove it? I know that I will have to drop the exhaust for access to the mount,but do I need to drop the cross member as well?
Thank you for your help
Joe.
If you are replacing a factory one with a factory one, the factory one mounts to the cross member along with a bracket (upright)
If you are installing one that mounts to the transmission, (and replacing a factory one) you will still need to removed the cross member to removed the aformentioned bracket.
I installed a Hurst Comp (+?) on my '76 with a ST-10. Hurst will supply instructions for your year install or go to the hurst site and download the instructions.
I did not need to remove the crossmember.
Yep, what he said.. I took all the bolts out of the shifter mount while sitting in driver seat, but the rubber boot was already gone.
