uralman
New member
i installed one on my 87 coupe. nicely made but had to alter it a little to make it fit.
worth the $$
Paul
worth the $$
Paul
With all do respect your comment is extermly shallow in scope!bradvette said:uuhhh, given cost vs. benefit, i wouldn't get all tnat excited about it
nothing personal of coursegolfman2008 said:With all do respect your comment is extermly shallow in scoop !
At what cost would one need to go through to enhance your cooling system ?
This is true , but the fan has no effect on anything else ! It doesn't increase the CFM into the radiator area and has Zero esthetic value . With the Big Mouth Air Dam you enchance the hole system in one easy install , ram air , cooling, recovery, trans coolers, any other add on as well . Plus you don't need to replace your center spoiler from damage any more , you can trim and no scraping. plus its well made and powder coated !bradvette said:nothing personal of coursecost? about $10-$20, for a low temp fan switch. clean the radiator if necessary. the fan switch will make a huge difference. super cheap. this is about all you should need for a C4. i do admit however that the thing you're peddling looks pretty cool.
golfman2008 said:I am sending the decal with a scratch gaurd for your Air Dam ! I moved and finally settled in ! I will send an email to you.![]()
