Previous Post indicates secondaries might open too soon? How do I figure that out and correct it? Its a rochester Carb
Here is an extract from an article written by Lars Grimsrud:
".............you want to get the secondary (air valve) opening rate set up. This is determined by the spring windup.
It is a very common “speed trick” to loosen the secondary windup spring so that the secondaries will open very quickly. This is the single most common cause of a severe stumble or hesitation upon acceleration or transition into the secondaries.
The secondary spring windup is adjusted with a small, slotted-head screw on the passenger side of the carb, right at the top of the carb on the secondary side. The screw head points right out to the side. 90 degrees from this, on the bottom, there is an allen-head lock screw that keeps the slotted screw from turning. If you have trouble seeing it, place a mirror under the area until you spot it. With a small slotted screwdriver holding the adjustment screw, loosen the allen screw about ¼ turn. This will allow you to turn the slotted adjustment screw. Counting the turns, allow the slotted screw to slowly unwind until all spring tension is gone. You can use your mirror to see the spring disengage contact from the pin lever underneath the air horn. If the spring tension was lost after only ½ turn, the windup was too loose. Bring the spring into contact with the lever. Note when it just barely touches. From this point, wind the spring up between ¾ turn and 7/8 turn. This is a good starting point, and will prevent any bogs or hesitations due to premature secondary opening."
(from this starting point)............"you can start unwinding the secondary airvalve spring. Relax the spring tension in 1/8 turn increments until the car stumbles on acceleration, then tighten up 1/8 turn again. You have now determined the quickest secondary opening rate that your engine can handle, and your secondary mixture is set."
